consistency
4894.5 In reply to 4894.4
Michael,
> The tolerances it targets is already pretty tight - it shoots for an accuracy of 0.001 units. Is that particular tolerance target a >problem for you?
the numbers aren't a problem. It's the fact that Moi says it's a solid but when I export anything done with deform not one other piece of software thinks it's a solid. This is clearly a bug in the deform. I attached a test. What the test shows is inside of Moi both objects are seen as solid but if you export both of them, lets say as stp files the deform object comes back with multiple errors in all other software packages. Moi is too tolerant. this is how I am using the word.
You did actually answer my question already though which is I can't tweak moi's tolerances. So I'm back to building things without the deform. Ah well... I will wait patiently.
Val
EDITED: 14 Jul 2021 by VAL2
