Michael,
This really isn't my issue.
My issue is that Moi sees the deformed shape as a solid (when no other software does).
When I export that solid to another piece of software the next piece of software finds a problem. If I can't tell in the Moi there is something wrong then it's a problem for me. It means I can't trust that aspect of the software, which means I can't send the file on to other people because they don't use Moi.
What I need is for Moi to see the same thing as other pieces of software.
So if moi says it's a solid then I would hope other pieces of software would see it as a solid. If moi sees it a series of surfaces then I hope other pieces of software see it as a series of surfaces. I don't care what it is (a set of surfaces or a solid) I just want it to be consistent.
What I uploaded is a demonstration of moi seeing both, the deformed and the undeformed, as both solid. but when I export the file and open it up in other software. The other software sees the deformed one as an incorrect open model.
Make sense?
thanks
Val
