Hi ed,
> The way i did it the first time was just pasting the shortcuts
> on my old ini file on windows, that way it doesn't work, but
> it worked when I just added one like L=Line. Here is the list
> of shortcuts I entered the first time:
So when you say "pasting the shortcuts" do you mean pasting them directly into the moi.ini file using some text editor application? If so which text editor are you using?
Or do you mean pasting them in one at a time using the Shortcut Keys UI in the Options dialog?
Because I'd like to try and repeat the problem over here.
If you're using a text editor program to edit the moi.ini file directly, make sure you save it as "plain text", and not as something like .rtf format which won't work properly.
