Tri-Braid Attempt
4877.12 In reply to 4877.11
Hi fleetfoot, those probably won't help you directly to do the weaving, but Flow will allow you to at least focus on making a weave that's all flat in a plane and then you can use Flow to bend it into the ring shape.
That at least takes one degree of complexity out of the equation.
Also you might want to check out this post that uses flow to map a straight curve that has a rise and fall in it onto a curved path:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4785.13
