flow problem
4863.2 In reply to 4863.1
Hi Val - this is a bug in flow - it has a problem with surfaces that have a collapsed down pole point in them like a sphere.
If you zoom in quite closely to the pole area you can kind of see a little disturbance in that area - the deformed result has some kind of little bit of overlap or something like that just right in the area around the pole.
So anyway that's what you're running into here and that's making some self-intersecting triangles in the STL output.
I think it should not be too hard for me to fix this bug up once I get a chance to focus on it, thanks for reporting it.
