Chris
No programmer here but what I learned digging into alternativa, like flare 3d and away 3d they are just libraries to add 3d functionality and interactivity that is not in flash. I put one model online as test..works very nice...I was getting like 60fps and zero on the cpu...but I have a high end graphics card...had a friend test it with a run of the mill card and it was reading 35fps and 0-1 on the cpu...the model was 35kish for poly's with a texture map. I am trying to write my on viewer script based off what they have online...so close..got the model in there rotating...now just need to finish with the keyboard pan and zoom. You can just export from them online but the swf gets big with a lot of extra stuff..hence trying to write my own. Wire fusion was sure a lot easier to use.
