Very bad fillet function
4830.5 In reply to 4830.1
Hi cx, in case you don't have an earlier version of the model available, I separated out the parts in the attached 3DM file into their pre-boolean state.
If you fillet the edge of the cylinder first like this:
And then do the boolean cut for the making the notch afterwards like this:
Then that should give the result you want:
There's definitely a bug though that was preventing it from working correctly doing the fillet after the boolean in this particular case.
