fillet help
4802.3 In reply to 4802.1
Hi beanworks - is it possible for you to post the 3DM model file instead of just a screenshot? It's much harder to analyze and examine geometry with just a screenshot.
My best guess from your screenshot would be maybe some difficulty in this area here:
If I had the model file to examine, I would probably start by looking in that area to see if there is possibly a little shelf in that spot - if there are any little surfaces in those areas then the fillet will be limited to whatever size the little surfaces are.
Also it could help to make the outside pieces there be made up of one single big surface instead of separate ones - it's usually easier on the filleter if pieces that look like they come from one cylinder like that actually are just one face instead of split into multiple separate pieces.
Also I would closely examine the top surfaces to see if there are any small edges or faces along any of those areas too.
