A Drone and Rail sweep advice
4773.1
Here I had a little fun exercise with this made up drone based on the predator.
However I did rack my brain on how to do the front of the drone. I did end up creating the top half with with a two rail sweep + scaling rail and the same with the bottom half but with a different profile.
1) Is this a valid approach or would there be a better way to do this?
2) I had to play around quite a lot with the rails to achieve what I wanted. I did get imperfections a quite a few times so had to constantly play with the points of my curves that defined my rails.
when defining a rail will having more points defined your 2d curve achieve better results?
Also once I defined my shape I had issues trying to fillet the edges and also "boolean union" the top half and bottom half. I ended up just placing very close together for the render
Any advice would be appreciated
Steve
EDITED: 9 Dec 2011 by STEVER
Size: 193.7 KB, Downloaded: 105 times, Dimensions: 1280x720px
