New Mar-9-2007 beta available now
469.16 In reply to 469.15
Hi Pilou, here is an example.
2 Circles, 90 degrees from one another:
Select one of them, then run Boolean intersection, then select the other one and push Done to generate this result by auto-extrude:
Because the original curves are still around and have not been deleted, you can turn on control points for either one and edit it and the intersection will update:
