Hi DesuDeus, it is possible to move the moi.ini file to anywhere you want, you then need to tell MoI where you put it by putting in a command-line argument to MoI.exe , with the path to the moi.ini file.
So you'd edit the shortcut that you use to launch MoI and immediately after the part that has MoI.exe in it, put in a space and then the path to your moi.ini file, putting " " around the path if it has any spaces in it.
So your shortcut target might look like this:
"C:\Program Files\MoI 3.0 beta Oct-25-2011\MoI.exe" "c:\some folder\moi.ini"
