Hi DesuDeus,
> Is it possible to make the popup diseapear as soon as you
> click one of the icon ? That would be cool :)
Yup, that's possible by making a custom dialog that calls an endDialog() function whenever anything has been clicked.
If you use the attached Lines2.htm file as a dialog it will do that, if you copy this one into the \ui sub-folder then you would use this script on a shortcut key to call it:
script: /* Show lines dialog */ moi.ui.createDialog( 'moi://ui/Lines2.htm' );
