New Twist command coming
4614.14 In reply to 4614.12
Thanks Michael,
> That might be possible, but it would be good to avoid controls for it that make you feel like you're taking a math quiz...
C'mon... couldn't you just imagine the suave look of a nifty scientific graphing calculator widget in MoI's side pane? ;-) I think that was a nightmare I had the other night.
I could imagine a check box in the dialog box like the one on the Spiral command, where if you check it you could then pick a twist angle at one end and then at the other.
As for an ease in / ease out control - If you could imagine a simple button in the dialog that says [with ease] that would add a spacing entry in the dialog, not unlike the one for the Fillet tool.
You could then ask for a numeric range by which to go from 0 to 88 mph in 6 seconds, so to speak, defining a soft transition on the ends - if the twist ends are inside an object's length.
For example: I could select an object, pick a start and end point, choose the rotation angle factor for one point and then the other, then specify the soft ease transition distance...
No, no... to much.... my ego would get drunk with power... ;-)
(simplicity)
Don't mind my creative rambling Michael, I'm still marveling at the twist tool's amazing potential.
