Hi Asanty,
> Hi Michael, how to make a variable radius or chamfer?
MoI does not currently have a variable radius fillet or chamfer tool - that is something that I want to work on adding in for v3.
Currently you would have to do something like build up some profiles and do a sweep or some other surface construction technique like that. Or really the best way currently is to export your model to some other CAD program that does do variable radius fillets, perform the fillet there, and then import it back into MoI. ViaCAD ( http://www.punchcad.com/c-12-consumer-cad.aspx) can be an inexpensive companion program to use for that purpose.
