Hi Gep, no problem, I'm glad you've got things working now!
But you may want to ask on the Luxology forum about some setting to make all polygons show up in the editor window instead of having back-facing ones being hidden in the display. There is likely some setting you can switch to make that happen and then you would no longer need to spin around to select those polygons, that would then make things easier.
