Hi Mike,
I downloaded and installed the font you have in question to the font library on my PC and it appears to do caps.
Also, if you are extruding from curves on a curved surface, you will probably not get a closed solid volume. You could try a straight extrusion, then merge or subtract the curved surface or solid to create countoured text.
Hope some of this helps.
Michael T.
Michael Tuttle a.k.a. mictu
http://www.coroflot.com/DesignsByTuttle |
