N Type Using Flow
4586.7
Hello,
Thanks for the compliments. It took me little while to get the knurling to match up exactly until I realized I needed to start thinking of how the knurl would look like if I unwrapped it from the connector body, then the seam ends matched up perfectly. It is also less hassle to extrude the diamonds a small amount on the underside so they will Union correctly. Placing the plane on top of the diamonds is a great feature of the Flow command because the knurling doesn't add to the diameter of the connector.
N Type
EDITED: 3 Feb 2025 by OSTEXO
