Hi Riko - but all you have to do currently is draw a circle and do boolean difference.
That's not very many steps already...
What kind of steps were you thinking of instead?
If you're placing holes in a repeated pattern drawing just one circle then allows you to use the array commands to replicate the circle into a pattern and then you can do just one boolean difference using all those replicated circles as the cutting objects.
Is it that you are always using a circle of a specific radius?
If that's the case then maybe the QuickCircle script would help, see here:
http://kyticka.webzdarma.cz/3d/moi/#QuickCircle
