Blend and match (V3++) ?
4556.1
if I'm not mistaking, currently blend work only from 2 edges of some surface(s). Will the match command work on the hole surface independent of how many (segmented) edge each is made of? Or as you did for the flow command next beta (projection), somekind of preview of how it will work?
Felix
