Question re constraining two curves
4555.13 In reply to 4555.12
> What about controlling which direction the blend is going in though
Wouldn't the parent curve govern which way the blend goes depending where you drag or pick the point, like if you're blending to a 180° arc once you've gone past the 90° quadrant point the blend would change direction, wouldn't it ?
> would you expect for it to always do the trimming
> or are you talking about needing some other way
> to control that as well?
Always trim once you've decided on the position and commit the command.
