Flow??? Just wanna play with it....but I can't make this work
4550.3 In reply to 4550.1
Hi Chris - so the way Flow works is that you have some objects you want to morph.
So you select those objects you want to morph and then you need to pick 2 surfaces to define how the morphing will take place - you pick a base surface (usually a plane), and then a target surface.
So those are 3 different pieces that you need to have:
1 - objects to morph
2 - base plane surface
3 - target surface
The problem is that in your attached file you are missing the #2 base plane object, you seem to only have an object to morph and then a target.
You need to create a plane object that is positioned around your object that is being deformed to define the base position.
