Flow on Revolved Surface
4549.8 In reply to 4549.7
Hi Mauro,
> Thanks Michael for suggestions
> almost tried many solutions,i think you cannot flow everything
> you want..at the end
Yeah not every design has a 2D element to it - if your pattern does not map well to a 2D pattern then Flow won't really be a help for that particular case.
> CPU's behavior : you see 4 cores but only one at 100% computation
Yes, that's normal behavior. It takes special and careful work to make an algorithm make use of multiple CPU cores, it is not something that happens automatically. Implementing a parallel version of Flow could be possible in the future at some point but for v3 the main focus is just on making Flow give a good result.
