After correcting a few simple bugs, (failing to name variables properly),
now have a parametric 2D Logarithmic Spiral.
Ran a simple Sweep with two circles.
The script is of the same pattern as other simple parametric scripts, based upon the ToroidalHelix Script.
Just plug in the proper simple parametric equations.
To use the script, just unzip it and copy the two files to the MoI3Beta command subdirectory. (Same subdirectory as MoI2. (Currently))
Then set up shortcut key under MoI3 options icon. (Can also do shortcut key under MoI2 options icon, for MoI2 usage.)
It might be nice to distribute the points more uniformly, not cluster them in the middle.
