Hi niko,
> Any word for the continuity options for the network command on the beta?
Nothing for that quite yet - I'll probably still be focusing on the new deform commands for a little bit here yet.
And most likely the main continuity tool will be a separate "Match" command that will allow you to modify 2 surface to be smooth to one another, no matter which particular command was used to create them.
I'm not sure yet if that will get built into the Network command as well or if that is not really needed with a Match tool in place.
