I noticed when creating an ellipse (center,width,height) and set manually the width and height, that the ellipse is not drawn immediatly like setting the circle radius manually does. Shouldn't it behave like the circle command does?
Felix
PS using V3 beta.
Edit: I've tried the diameter version after entering values manually and hitting enter the ellipse is drawn immediately, same as the circle command (center,radius)...
