Aircraft Wing Root Fillet
4488.7
I had a similar problem earlier with a propeller. I just wanted you to know it can be done with MoI, and once you figure out how to do it, it can be done very easily and quickly. The thing is you have to experiment a lot to figure out how to get it done. I can't say specifically for you but the biggest things I found was that switching to the mm unit system helped. Then switching back to the meters system that the model was acutally in. Also making sure that in your case the wing is a solid and then the body is a solid and unioning them. Then make the fillet. If MoI can't make the wing a solid or the body a solid then there is a problem. Like Michael said you have to clean up the surfaces. That was something I had to work on too. Its not intuitive at first, you think it should just work no matter what. But in reality it will only work under certain circumstances. If you are willing to spend the time on it and not give up you can reach your goal. Michael and BurrMan helped me out with my problem, which is very similar to your problem. So definitely try out what they are saying and more. I tried a lot of stuff after I understood what they were saying. After awhile I got it done to a very simple process.
