Installer un script
Voilà la réponse de Michael
Hello Pilou
the script plug-in will usually be 2 files in a .zip archive. You need to download and unzip to get the 2 files, then these files need to be copied into MoI’s command folder.
On mac to get to the command folder right-click the MoI .app icon and choose “Show package contents”. Then inside there go to drive_c/moi/commands – that’s where you need to copy the files.
That will make a new command available to MoI, with the command name being the base name of the files. So for example if the 2 files are named NewCommand.js and NewCommand.htm , the new command that those make available to MoI is named: NewCommand .
To trigger the command set up a shortcut key and put in the command name on the right-hand column of the shortcut key.
Hope this helps!
Faut-il que je traduise?
S'il y a toujours le message d'erreur
Donner la config du système, le fichier OBJ, si c'est confidentiel l'envoyer à Michael: moi@moi3d.com
EDITED: 19 Jun 2015 by PILOU
