Flow weirdness
4474.4 In reply to 4474.3
Hi PaQ,
> Would be possible to have an option to flip the UV direction
> with the flow to surface command ?
Yup, I just finished up that part for the next v3 beta. In the next beta it will pay attention to where you click on both surfaces and it will match the uv directions so that the edges that you clicked near are aligned to one another, you click near to one side of an edge.
For now it only aligns by the built in natural UV directions, so to make the case you've got there work in the current beta you've got to take your plane and squish it so that it is narrow and tall instead of short and wide, and then rotate it by 90 degrees, and possibly flip it upside down - that will then put its uv directions to be how you need it. But that won't be necessary in the next v3 beta, you'll just click on each edge where you want to have things aligned.
