Hi Burr, well it does actually array it along the path but because your point is located off of the curve there is a kind of offset distance that comes into play where each copied version is at that same distance away from the curve.
With only a few points being generated it will be kind of hard to see the pattern - try making something like 100 copies (set Item count option to 100) and then you should see the pattern of how it is tracing along a kind of offset curve.
To get more control over something like this you probably want to make a curve that the point is sitting on to array along rather than having one that is a fair distance away from it which will involve that kind of offsetting.
