Hi bemfarmer,
> Try google, "drill bit cross section"
> cgsociety.org shows how, in general.
> Extrude and rotate a cross section (somehow.)
So probably what you would want to do for a cross-section like that is to think about creating it by cutting a base shape.
So you'll start with just an initial solid tall cylinder for the main body, then build 2 tubes that follow a helix path twisting around it, and then use boolean difference to cut those tubes away from the main body shape.
