Tangent Arc?
4457.5 In reply to 4457.4
Hi OSTexo, it's not really particularly difficult to draw that in MoI either - it only takes a couple of seconds.
You can just use the regular arc from center point tool, type in the radius value that you want and drag out a construction line to get a snap point for where to place the center point.
Then you just pick the center point, pick the point on the curve and you're drawing a tangent arc at that point.
I can probably streamline things just a bit with arc continue, but with the above process you're talking about something that's pretty easy to do already...
Let me know if the steps that I've described here aren't making sense and I can make a demo video for you.
But I will also see about tuning up arc continue to increase the convenience factor a bit further. It's not like this will be a very dramatic improvement though - it will just avoid creating a construction line.
