Network Curve selection
4453.7 In reply to 4453.5
But also you mention being worried about polygon flow - what is it that you are planning on doing with the mesh that you are specifically concerned about that?
If you need a particular kind of polygon flow because you plan on doing sub-d smoothing, you really aren't going to get that kind of a result from MoI's export. MoI's export is more oriented towards making an efficient polygon count with a lightweight wireframe using n-gons. That's a very different kind of mesh structure than a sub-d friendly one which requires a lot more tiling of large areas into numerous quads instead of using something like one big n-gon for a large flat face.
See these previous forum posts for some additional explanation:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.132
http://moi3d.com/forum/index.php?webtag=MOI&msg=4096.18
http://moi3d.com/forum/index.php?webtag=MOI&msg=3488.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=3196.11
http://moi3d.com/forum/index.php?webtag=MOI&msg=1536.30
