Here is another method I learned from a fellow TurboCAD user but it works in MoI as well.
Snap a closed spline by control points to a rectangle and a line. Show points.
Extrude the rectangle if desired, otherwise direct entry can work.
Snap the four corners of the spline to alternating corners of the box.
Remove the box and sweep a circle on the spline path.
