Make It With MoI
4388.124
WOW!!
Thanks guys! LineWeb has potential. I saw mention of LineWeb before, but thought it was some kind of exclusive feature, overlooked it on that page. I use one or two other script plugins including SullScreen.
I took LineWeb and Pipe for a test drive here:
Had problems with Pipe. It didn't produce the inside dimension. (Does Pipe2 fix that?)
Michael, if it's possible for more plugins to be created, have you thought of some kind of pop-up screen, menu or single button activated window that comes up with an icon list of non-ui scripts (plugins). Reason I ask, ise plugins are real easy to forget about or "out of sight, out of mind", especially when a seldom used key or command line entry has to be used.
I really like your proposal to add a dialog for extra controls!
