| Hi Anthony, I've attached here an updated version of the script which should now import these files ok - this version handles multiple spaces between each coordinate.
You'll need to set the Delimiters: option in the command to "Spaces" here:
and then the only other thing is that these points are at a pretty small scale - they fit in a box something like 0.03 units across, so you'll need to zoom in to see them well. You can zoom to see them by doing a right-click on the "Reset" button in the toolbar that's at the bottom of any viewport.
You'll probably want to scale them up before working with them.
        - Michael |
