Thanks burrman,
I think that would make the final scale that you worked in with you applied the .005m radius 10,000:1. The reason I had the crazy 1,000,000:1 scale was to get the trailing edge radius to display right. I may start from scratch and see how it goes again. How did you actually do the radius and the G1 blend. I didn't understand how that worked because the intersection line wasn't coming out at the actual intersection.
