3Ds Max EditablePoly to MOI
4372.1
It's possible to curves from a 3Ds Max editable Poly (NURMS Sub D surface) object into MOI.
Check out this thread on the Area for background on this process.
http://area.autodesk.com/forum/autodesk-3ds-max/modeling/another-patch-question/
select all edges
apply mesh smooth (NURMS mode)
apply a edit_poly modifier
subobject mode = #edges
press “create shape”
Next export the new lines as an IGES file.
When it comes into MOI many of the cures will be in segments but you can join them and rebuild them. This will give you a fairly clean set of curves to start building MOI surfaces from.
Size: 68.5 KB, Downloaded: 98 times, Dimensions: 657x558px
Size: 53.9 KB, Downloaded: 89 times, Dimensions: 657x558px
