Also a convenient way to draw the wire scaffolding for a pyramid in the 3D view is to pull up a construction line in the z axis direction so that you can track along it to place a point at an elevation above the construction plane.
Here's what that looks like - to make a construction line you hold the mouse button down and drag it instead of just clicking it as you normally do to place a point. Make sure you have "straight snap" enabled in the bottom toolbar so you can get the z axis snap line. Then right click to repeat the line command to draw the next one.
