Hi Ed,
> Can you lay that notched object down flat and deform
> it around the same curve?
I'm not quite sure if I follow what you're asking about here - but there will also be a different variant that will allow you to map from objects arranged on a plane to some other surface rather than mapping between curves.
> If so, then we may need fewer steps to project designs
> and text onto a cylinder?
Yeah I think it should help out a lot for applying text on to other shapes.
