Hi Marco thanks for the bug report!
> - UI-size skips instantly to 30
Unfortunately I can't seem to repeat this one over here, I'll keep trying on a few different systems.
I may need to add some kind of extra debugging output to the next beta to try and track this one down.
> - Long object names in the Browser (might be normal behaviour..)
Yeah I wasn't quite sure whether to leave that or not because it is kind of good with long names to see as much of the name as you can.
But it's pretty messy having things draw over top of each other like that.
What about a kind of hybrid behavior - if there wasn't any selection dot there at all then I could let the text run into that selection dot area, but if there is a dot displaying then the text would get truncated before the dot.
The other option is to have it always truncated leaving the dot as a completely separate column but that means the selection dot will have reduced the display space for the text name in all cases.
