Is it able to start up and appear to run normally on your systems?
There have been a lot of changes in this version to how the UI and script system works internally, so it would not be too surprising if there were some glitches to work out.
Ultimately though having more of the UI code more self contained like it is now will help with stability in the long run since there will be less variation between systems.
