| Hi Burr, that process could actually work!
 But you could also generate some insanely complex surfaces from it that may bog things down too much.
 The surface that ZSurf generates is already pretty heavy itself - if you then try to morph a really pretty heavy surface onto something else, the morphed surface will generally get more complex yet as it will be trying to reconstruct the surface and fitting it to the deformation.
