Hi Mike,
> If you wanted to put type on two surfaces at one like
> that penguin's belly, could one just cut the type on
> the plane in two representative sections and wrap them
> on the two respective surfaces?
Yeah that would probably work.
> Is there some measure to control on where things line up
> and are positioned once processed?
It's controlled by the position of the object inside of the base plane.
For example - position the object so that it touches the edge of the base plane, then the morphed result will touch the edge of the target surface after it is processed.
Position the object in the center of the base plane, and it would go in the center of the target surface, etc...
