Hi Rudl,
> How will it be placed.
It is placed on to the target surface in the same relation that it has to the base plane.
So you can adjust the position of either the object inside of that plane, or increase the size of the plane itself to alter how it ends up being placed on to the target surface.
> Will it be possible to move it on the surface, or can it be scaled.
You would move or scale the base object around inside of its base plane to do stuff like that.
> Perhabs, when the originial will be conserved, moving it to X
> the copy also will move to X and so on.
It will be possible to enable history updates so that you could change the original object and see the result update.
