The egg revolve is malformed, and the "pre-trim" hole in the door doesnt match the egg also...
You can untrim the joind surfaces by running seperate and selecting all the edges and delete, then re-join the 2 surfaces.. I redid the revolve by extracting the edge of it and deleting the original, then "flattened it" with the edit fram in the top view. Then I went to the right view and used the rotation widget to align the eggs edge with the joined surfaces edge and ran trim and selected done for a trim all, then deleted the outer egg surface and the joined surfaces cap that was left behind...
