Creating curved surfaces
4344.1
I'm still working with the curved surface, trying to fashion a plastic tube with the curved end like in the picture. I need to generate a g-code file to cut that end with my CNC router. Since I'm starting with a plastic tube, I want the router to cut just the end curves and not try to cut the sides. To do this, I'm modifying the drawing in order to limit what the CAM software sees when generating the g-code. The first thing I want to do is cap off the inside of the tube so that the CAM doesn't try to cut the inside wall. I have extracted the top curve of the inside wall, made a copy of it to the side of the tube. Now I want to create a surface from that outline, but I can't figure out how. Can MoI make a surface from that closed curve? I think this is a little bit different than the other questions I've been asking about this particlular project.
Mark
