After a Slice
4339.4 In reply to 4339.3
> Does it possible for the perfection to enter another angle
> at the start? (negative or not?)
You can make it use a different angle by editing the script in a text editor - at line 30 of the file you'll see this code:
// Angle to rotate by.
factory.setInput( 2, 90.0 );
The value 90.0 there is the rotation angle value that will be used. So if it's not going in the direction that you want you can change that to -90.0 instead (you'll need to restart MoI if you've run the command once in the current session).
> PS does the "Centroid" of the object is the "centroid" of the Edit Frame?
Yup, it should be the same I think.
