Hi Burr, you mean to keep the endpoint of an open curve locked down and not float around with the rest of the points?
Yes, that could be possible and pivoting around the endpoint doesn't really cause the same kind of bulging issues since it doesn't pivot the piece of the curve behind the point since there is no more curve on the other side of the point in that case.
That's something that should be pretty easy for me to add in as a moi.ini option in MoI v3, I've added a note to do that.
