Overlapping lines
4313.2 In reply to 4313.1
Hi Ed, do you mean something like lines that are duplicated and stacked right on top of each other, or do you mean lines that are overhanging some shape.
For the latter, you can use the boolean commands on lines which can sometimes be useful.
For example if you have a bunch of lines and a circle like this:
You can select those lines and run Construct > Boolean > Intersection, and then select the circle as the object to intersect with, that will keep the parts of the lines that are also contained within the circle, resulting in this:
