Any ideas on how to model something like this??
4299.3 In reply to 4299.1
So something along these lines:
A few shapes to build the upper body part with a Loft:
Then in the side view, one ellipse profile and a path, to make the handle with a sweep:
So now you've got 2 solid pieces that are pushing through each other like this:
Select them and run Construct > Boolean > Union to fuse them together into a single solid. That will create an edge where they intersected each other, select it here:
Then you can run Fillet to round off that edge:
Then it looks like you'd want to do some kind of a sweep to build a curved cutting surface to kind of scallop out the sides, check out the scalloping step in this desert eagle example for something similar:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3321.17
